Tekvektor
i.e. the fastest way to get a correct answer on the internet is to post a wrong conclusion
here is the basis of my system. Its being built to go into a 2005 Ford E350 Superduty with and existing factory Dual Batter system with a 3 way, 1, 2, all or off switch for the battery system.
2 x 200w BougeRV Yuma CIGS Panels (Open Circuit 31.5w) which will be installed on top of a Wasatch Overland E350 High Top.
Feeding into a Renogy DCC50S 50A Batter Charger w/MPPT which is the common Negative point for all equipment.
4 x 100w Oupes Foldable Panels connected via Paralell cables and anderson connectors to a Renogy Rover 40A MPPT
Connected to 4 Lomrige LiFePO4 12 Volt 200Ah 100A Max Discharge Batteries (Initially Though Paralell but nearly 300amps of draw means thats not real feasible)
Also connected to the batteries (not sure if should be directly to the batteries or connected to the DCC5WS
The attached power plan shows how I *PLAN* to connect it all together and where I think I need the appropriate fuses. Is there anything that jumps out as wrong? Rather than Running them in Paralell would a busbar be a better option? Series Paralell? HALP.
Power Calculations for the Build
Power Calculation | Dialy | Watts | Hours/Day | Watts Used | Amp-Hours | ||||
Roof Fan | 2.4 | ||||||||
A/C | 750 | 10 | 7500 | 625 | |||||
UM790 Pro | 85 | 8 | 680 | 56.66666667 | |||||
Inverter | 30 | 24 | 720 | 60 | |||||
Controller | 1.2 | 24 | 28.8 | 2.4 | |||||
Refrigerator | 8.3 | 24 | 199.2 | 16.6 | |||||
Induction Cook Top | 1800 | 0.5 | 900 | 75 | |||||
18.5in 100hz monitor | 5 | 6 | 30 | 2.5 | |||||
GL.iNet GL-SFT1200 Access Point | 6 | 24 | 144 | 12 | |||||
Ceiling Lights | 1.3 | ||||||||
Garage lights | 1.3 | ||||||||
Total | 2685.5 | Total | 855.1666667 | ||||||
Maximum Amp Draw (Amps) = (3000 Watts ÷ Inverter’s Efficiency (%)) ÷ Lowest Battery Voltage (V) | 272 Max Amps | ||||||||
