I'm helping a friend install a solar system on his mobile bar, and I'm wondering if people have any tips.
Here's his rig, The Sandbar:
He's bringing it down to Baja California (Mexico) in a few months and wants to run off solar with as little fuss as possible. His needs are pretty simple:
- a stereo that pulls at most 75 watts when on full, more like 20 watts usual use though
- a 70 pound ice maker that pulls about 190 watts (it's this one). Won't run all day. I'm interested in alternative ice makers if anyone happens to have a suggestion. And I haven't run it off a inverter yet, I'm hoping it doesn't have a startup surge when the compressor kicks on.
- a bunch of lights that pull a max of 30 watts
So that's about 300 watts max draw. I'm thinking he'll probably eventually want a chest freezer fridge at some point, and maybe want to run a projector, so I'm trying to give the system room to grow. But there's budget constraints, he's trying to keep it cheap-ish.
At the moment the system I'm planning consists of:
- four 280 amp hour Eve cells (or similar) wired for 12 volt. Not purchased yet, if anyone knows of a good source or something else we should consider, very very interested. Would love for that to be under $800 with BMS shipped, but I know that's a long shot.
- three 260 watt solar panels (purchased for $75 each! So awesome how cheap this stuff is getting. Planning to wire in parallel so he has freedom to shade one or two panels with cargo, and the charge controller is only 100v)
- I have a Tracer 40 amp charge controller that I'm donating to the cause (this one), but that's less than the theoretical max capacity of the solar panels, which is 65 amps. The panels will be flat mounted, which means I think about 15% less capacity (so we're down to 55.25 amps). I'm a big fan of over panelling, but since he'll be in the tropics (just south of the Tropic of Cancer) I'm worried we'll be squandering a lot of amps. Any thoughts on whether we should bite the bullet and buy either a bigger charger controller, or maybe a second controller that we connect one of the panels to? Or is this array unlikely to make much more than 40a given this setup?
- And any thoughts on how well the Tracer charge controllers work with LFP batteries?
- a Peak brand 800 watt inverter that he had, probably purchased from Home Despot (link). I'm a bit worried about that dying on him. Any recommendation for a good and relatively cheap inverter? I always use Xantrex inverters, but they're a bit outside his price range.
Planning to buy:
- this 10 gauge wire
- these branch connectors
- these fuses (one for each panel)
- this fuse for the battery
Anyway thanks for any help. Trying to avoid the inevitable stupid mistake or three.
Planning to buy:
