Yes, drilled small corner holes and use dremel. Had to cut away part of the fuse mounting plate. Bracket was a piece of 2mm (?) aluminum. Had to file it for snug fit in DIN mount part of breaker.
I tapped 2x 3mm holes into leftover part of the fuse mounting plate. Also tapped 4mm hole into aluminum bracket.
My son 3D printed a stand-off for the loose end of the fuse holder and also a cover/guide for the positive terminals to guide the cable.
I used some of the 50mm2 supplied by Seplos as an extra to my DYI kit. Cable fitted into the breaker terminals very tightly but without the need to trim any of the cable strands.
50mm2 cable core measures around 8mm diameter (FYI
@netforceatg)
Some touch up paint afterwards to cover up the damage...
