Am I completely off here.
I'm building a 12v battery for my caravan on 4 LifePO4 cells of 230AH.
For this I bought a 100A BMS from DALY to be able to drive a 1kw inverter.
However - having received it, i happily hooked it up and everything seems to work as expected - i can wonder why the app requires GPS to be activated to use bluetooth, but that aside.
When dimensioning the cables from battery to inverter I realize that I need at least 25mm2 cable (4 awg) to handle 100A in well ventilated surroundings.
And then I realize that the cables coming out if the BMS is 7Awg. That's good for up to approx 30a.
So - am I off here, when I say "no way I'm building that into a closed box along with my battery cells" ?
Jørgen - battery diy newbie
