Hello everyone
I have A bluejoy Battery 200Ah 16s
Equiped with Daly BMS 150A
While trying to upgrade the BMS to connect to a Sorotec inverter I accidently reset the BMS To factory settings. Everything get blank.
I set again all parameters and BMS work again
But still one problem, current reading is not correct reading on the bluetooth app or PC software is 6 times greater than real current.
I tried calibration using PC software but no result,
In these photos, charging is 40amp reading is 216.5, calibration is rejected by software, red flag.
Does any one has solution
Thanks and regards to whom read this post
