Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 21,808
Load shedding relays? Did a quick Google search but still seems a bit opaque. Seems to be for intermittent large loads that shut off quickly?
RTFM Sunny Island. If battery drains to shut-off, you have the problem of needing to black start.
Not such a big problem with DC coupled PV, just inconvenient when internet powers down because you ran the washing machine.
If a DC coil relay, look for good "economizer". The SMA branded one has two coils in series, shorts one out when open for high pull-in strength.
"One" for your sister will likely be DC coupled.
But we just learned Sunny Boy -41 model works at 120V!
I like AC coupled, which is how mine is set up. Old model Sunny Boy are fine for off-grid, although not accepted by utility for new on-grid installations.
