Deciding to DIY my solar battery was one of my worst mistakes ever
Yes so consider me out of the running for any experiments like, "can a Victron SCC that's placed in a freezer outperform one at ambient 75F thats approaching the temp of the sun due to less derating?" :)
Dunno, might be worth the doghouse for a night or two to figure that one out. :love:
Considering that buying prebuilt batteries would have cost me about $9k more, a couple of hundred Dollars of waste is not so bad, I think.
Also by using the savings on extra battery you can reduce the size of wire in most cases.
Example I have 4x 280ah batteries with 12kw inverter. The most one battery will ever see is around 60a. Wire size for that is reasonable
Why not wire oversized in that case so that if a battery or two gets pulled, you aren’t self limiting your power
You could do that.
Or buy more battery 😆
You had me spitballing an idea to save some money but I think I’ll stick with 2/0 from battery to bus lol
4/0 from bus to inverter
2/0 from battery to busbar? How big is your inverter and how many ah of batteries are you planning?
I'm old enough to remember punch cards and being so excited to get an 80 column graphics card.
But all this talk of remembering back about building computers does remind me of the classic Monty Python skit about "back in our day" (which I am so guilty of).
Oh how times have changed. My kids equivalent to "when dinosaurs roamed..." is "the olden times like when phones were stuck to the wall."
Back on topic. For me, I really enjoy the discovery and tinkering of DIY.
Luxury. They were lucky!
4-15kwh batteries each with 200ah BMS
10kwh inverter
Each battery has a disconnect so I can run max or close to max output from a single battery if required
Ok I don't see a world where you have 4 batteries but switch down to only one but if that's a possibility then it is what it is and you size your wire accordingly.
Oh I sure hope I don’t encounter a situation that would leave me down to one, but if there is…..!
Mainly research is what's time consuming. Currently I'm trying to figure out the correct torque figure for the battery fixture I created. One person on this forum says:
"300 kgf looks to me to be 660 lbs of clamp load. 25 in/lbs of torque on 5/16-18 threads"
another guy says:
"The spec from EVE was 300 KG force which rounds off to 660lbs. Battery face is approx 6.85"x 7.874" = 53.94 sq inches
660lbs/53.94sqin=12.23 lbs per sq inch
Divide 660 by 4 bolts that's 165 lbs Axial (clamping) force per bolt.
Using 4 course 1/4 in threaded rods that should equate to roughly 8 INCH pounds torque per bolt. Realistically, that's a snug twist of the wrist on a regular nut driver for the average build mechanic."
So 1 person says 25 in/lb, the other says 8 in/lb, I don't know which is right. If anyone in this thread happens to have authoritative information, that would be great. My fixture is using 6 threaded rods.
1719278180938.jpeg hope this helps you.
LOL... lucky you... I had to use a soldering iron to build my first computer. Not just for connecting bits together, but soldering all the components to the PCB... Yes, I am that old 👩‍💻👵
Lucky you. I started out with bread boards :) PCB's were a ways off for the home market then.
On a plus note fixing the commercial stuff was easy since the traces look like interstate highways compared to todays multi layer microscope need to see things.
