Woops, mega not mili.Power like that you could probably get from those gadgets that generate by motion of clothing, or harvest from the ambient environment.
Energy harvesting - Wikipedia
en.wikipedia.org
en.wikipedia.org
Man, I spend about $100/wk on gas, and $300 round trip when I go to camp.Tons of people buy a new car to save money on gasoline. Sure, great choice, take on a $600/mo car payment to save $40/mo in gasoline.
I'm one of those people. But I went from an 11mpg Diesel Dually to a $600/mo Tesla and saved about $400/mo in fuel. I'm gladly paying that extra $200 to save my kidneys from that solid axle they call suspension... lolTons of people buy a new car to save money on gasoline. Sure, great choice, take on a $600/mo car payment to save $40/mo in gasoline.
You just need more solar and a bigger battery.That's the idea in theory but the reality is that we lose power during winter storms when the house is using the most energy ever and there is no solar production. The battery will be drained in half a day then it's on to the generator, which one could just have bought the generator and skipped the battery and be in the same boat
I spent most of my money on women and wine.Signing up on some DIYSolar Forum... so much of my time wasted I could have been meeting girls...![]()
Isn’t that true.Shit, I thought me welding and then vaporizing one fo the BMS wires was bad. I got more batteries to build. Honestly I hate the assembly part. Feel like I’m trying to diffuse a bomb.
oh wow. I was wondering what would happen if I didn't ground the solar panels and this tells me. thank you for learning this lesson for me. lol. now i just have to figure out how to ground them....Oh and getting zapped by ~150VAC by touching ungrounded solar panels wasn't too pleasant. But, I didn't know such a thing was possible, so it wasn't totally my fault. Only by researching the subject on here did I know it was possible. Luckily it wasn't that bad of a situation. Seems like we're just the guinea pigs for some of this stuff..
Yeah, I didn't know about this phenomenon until I read about it on here. There's several threads on the subject on this forum.oh wow. I was wondering what would happen if I didn't ground the solar panels and this tells me. thank you for learning this lesson for me. lol. now i just have to figure out how to ground them....
I have about a thousand questions i need to ask before i do my main system. lol
it has to tie back to the inverter? what if I just stick it in the actual ground?Yeah, I didn't know about this phenomenon until I read about it on here. There's several threads on the subject on this forum.
To avoid detailing this thread, I won't go into too much detail, but basically you need some kind of clamp to tie a ground wire to all your solar panel frames. Then that ground wire needs to be fed back to your inverter/home earth ground.
It wasn't too bad of a shock, more of a tingle, but it was a surprise to experience. Imagine my "shock" to measure ~150VAC between the frames and a rebar post I had driven in the ground by the array.
No worries. Here's one thread that talks about the subject. There's others, just use the search function and put in "grounding arrays", "grounding PV", etc.it has to tie back to the inverter? what if I just stick it in the actual ground?
oops. I just saw this part lol. maybe i should create another thread. there are so many posts here that it takes forever just to search if something has been discussed before
Sounds like a success, not a mistake. Well done.Ecoflow Smart Home Panel, I started getting this out of phase error and I only had one 240v connection on Circuit 1 and circuit 2.
This had been working flawlessly for two years prior. So I checked all the wires in the SHP and replaced the breakers in the SHP. Did a lot of searching in this forum and other sites which led me to believe he contacts were too short. So I filed the breakers down on the short leg ones and replaced others. Still had the same error so I checked my well pump (this was the item on the 220v breaker), checked my starter box and found no problems. Still getting the error and about to pull m hair out. My wife was in the process of calling an electrician to replace our well pump.
I decided to pull the wires out of our house breaker box and noticed a dark blue color at the well breaker.
There it was the breaker had shorted and burned one of the two contacts off therefore single phasing the well.
Long story short, New breaker ordered and problem solved. Thank goodness I didn't need a new well pump and I found it before I paid an electrician $500.00
Bummer!!it was made in 1992 i can no longer get parts to fix it..
At night I lie awake and think of all the creative ways that 3/4" still can be enough lol.175' of buried conduit that I should have gone a size up on.
Thinking large culvert style big enough to crawl through yourself. Just in case.... Also good bugout escape tunnel dual use.At night I lie awake and think of all the creative ways that 3/4" still can be enough lol.
Held on by the cable?Forgot the last two tie downs on my sinclair rack, don't remember how/why (other than being in a rush), more than a few wind storms everything was fine, finally after one winter time high wind storm (tho no snow...), noticed the following after seeing reduced power on one string
In seriousness though if one was to build a power house in the backyard to avoid risk of catastrophic fire, I'm thinking connect to the house via a 240/50A inlet and transfer switch by the grid meter, like if I was hooking up a portable generator. Then the only potential UL code requirement in the house would be the transfer switch/method. Could even do an interlock on the main panel. My big loads are all propane except central AC and that's only 2 tons. But then for the grid input to the inverters...another 240/50A in the other direction, from house to powerhouse.
If the powerhouse was in a trailer....nothing for code enforcement to get their panties in a twist about
