SolaroSsaurius
- Aug 27, 2022
- 171
Hi all.
I need some insights!
I'm building a system around a 24v 5000kVA Multiplus II - but this is applicable to any situation, I guess.
Instructions state to use a 400A fuse and 2x50mm2 cables (under 5 meters) to battery (LiFePo4 24v 280Ah , EVE LF280k based, with a JK 200A BMS)
Spec sheet:
Cont. output power at 25°C: 4000 W / 5000 VA
Peak power: 9000 W
Max. battery charge current: 120A
Maximum AC input current: 50A
If everything goes according to plan, I'll never use more than 140A (including inverter's 96% efficiency for AC loads + DC loads)
My understanding (which could very well be wrong) is that this 400A fuse and this brutal cabling is aligned with the peak power:
9000w / 24v / 96% efficiency = 390A, next aprox fuse would be 400A
May I go down to a 175A or 200A fuse and wire it accordingly?
200A at 24v, using 2% voltage drop for 2m (1m length and return) would be 2x 25mm2
www.fabhabs.com
Thanks in advance for your opinions!
Regards
Spec sheet:
Peak power: 9000 W
![www.fabhabs.com](https://static.wixstatic.com/media/8722f4_50585148d6d048279ab864a4daf81e16%7Emv2.png/v1/fit/w_2500,h_1330,al_c/8722f4_50585148d6d048279ab864a4daf81e16%7Emv2.png)
DC Cable Size Calculator | Fabhabs
Easy calculator to size DC cables based on their length, current, and citcuit voltage. Ideal for 12V and 24V systems such as campers, van conversions, and solar projects. Need to know how thick a cable needs to be for a solar panel, fridge, battery, or motor? Use this calculator to find out.
Regards
