Hi, I have 3 (2 more coming) 280ah 16s battery boxes with SEPLOS CAN and LCD/BT
I have paralleled the batteries through RS485 and dip switches, can seen the individual and the whole pack in BMS tool.
If I switch the dip to 5 on and 1 off for CAN and connect it to the Deye, setting 00 it shows battery voltage and I know it sees all packs as the discharge/charge A have multiplied.
However, I do not see the detail info about the individual packs on the Deye LCD. Should I even ?
Any setting on the BMS or Deye side I could try? Hooking up the parallel packs using RS485 port to Deye BMS port - no luck, comms error...
