Also with mixed Seplos 10E + 10E + 10CThat's great. These settings are working for me with a deye 10k and two seplos bms too.
Hello, I have managed to connect the batterymonitor v 2.1.9 to my BMS. I have 5 battery packs. The software is able to see only 4 of the five. It is not able to see the pack number 00.this is coming from the bms..
please see in the faults log what the error in normal human language is (f errorcode).
my best guess is a cell inbalance in one of your batteries
set dip 5 ( master ) off and you'll be able to see all you batteries.Hello, I have managed to connect the batterymonitor v 2.1.9 to my BMS. I have 5 battery packs. The software is able to see only 4 of the five. It is not able to see the pack number 00. View attachment 158307
Hence I am not able to investigate the error that I am getting above.
For the sake of troubleshooting, i have connected the RS485 cable to the first battery (master) and saw 4 batteries. I connected the same cable to the lat battery and I saw the same 4 batteries. So it is not a cabling issue.
I wonder if anyone can help? I am not sure it is a software issue...
Hello. These are the errors I am getting:for bms logs/faults you will need the windoes software, logs are conviniently located under "log"
you inverter fault log can be found under system setting -> device info
As a reminder this is the summary of my problem:Hello. These are the errors I am getting:
So either :As a reminder this is the summary of my problem:
I have a 21kWp PV installation connected to 3 deye inverters of 8000 W each set in parallel. They communicate via CAN with a BMS with five batteries of 200 AH 48V each.
From time to time, I am getting this error from my BMS: 0x0100 0x0000. As a result the Deye inverters stop seeing the fiv batteries and drops the charging and discharging max current from 262 Amps and 495 Amps to 52 Amps and 95 Amps.
See pic for error:
Ay idea how to solve this issue? I have contacted the battery vendors and they could not help.
Hello. It has been a while. I am still having this same issue. To clear it, I power off my five batteries and then turn it back on and the error disappears. My Deye end up seeing the five batteries until further notice… in the past year I recalled all five batteries and set them at equal length to remove any possible imbalance. This did not help. Any clue how I’d be able to solve this issue ?this is coming from the bms..
Hello. Actually when i disconnect the comms cable (Serial) from the master battery, the BMS sees only one battery instead of the five I have. I think this is a normal behavior. Is that what you are suggesting? What i did now is switched the master role to the second battery.So either :
1.You have a cabling issue
2. You haven't setup your dip switches correct
3 you are running different versions of the BMS that aren't compatible
To exclude things..
Leave batteries in stack , but disconnect comms cable, if they are balanced you should be fine.
If error doesn't occured with only master connected, connect next pack, see if error occurred, if not.. next
Right up untill you identify BMS causing issue.
If master generates issue, use other battery as master, if error still there, replace utp cable
