Deye: Is remote configuration possible?
burgerking
Subic, Philippines
Hi,
I am sick of having to configure my Deye on site.
Is it possible through APP to configure Deye remotely?
I heard higher ups can view our config and such.
I also use Solarman, but it is for viewing.
What I want is ability to review and change these settings:
etc
etc
(of course not necessary seeing the same screen, but reviewing and settings the values).
Can solar assist do this?
Solar Assistant can change those settings on the Sol-Ark so it should work with the Deye.
Are you sure the Solarman account you have is set to Installer level access?
I am not sure.
Is this done only when creating the account?
Or is this something I can switch/change anytime?
I think it has to be done when creating the first account. The Installer can then add in other accounts for viewing.
I had no idea what I was doing at the start so I called Sol-Ark and they upgraded my first account to Installer. I am pretty sure I could have done it without them but I was juggling 20 different things at the time so I just took the easy route.
Currently, Solarman could not process "gmail" accounts.
So I went and removed the plant and created a new account (using yahoo), and this time I specifically set "Installer".
Still no go
Seems that I need to get Solarman/Deye to enable it, like how you got Sol-Ark to enable your account.
Yes I suspect they will have to activate it with Installer permissions.
Deye will activate remote control if you email them at service@deye.com.cn. Also they will reduce the data refresh interval to 1min if you ask them so solarman will update every 1min instead of 5min
Why it s late update of reading not live on the app solarman… and are u sure they can help us fix that issue and let us change remotely
Still no go
Not true i use gmail on solarman app
live updates take resources to process. Solarman is free. If they charged like $5 a month then they could have done live 1 sec updates.
And yes they will reduce it to 60 sec remotely
Do u think growatt or other competitor brands are live not late like solarman
Are you sure solarman is 60 sec i feel it s more like 2-3 min
I got updates from my Deye in Home Assistant every 60'' thru Solarman from 5 to 15'.
For remote is 60'' but fail communication a lot so I do it locally it's safer and faster, you only need to know the serial number of the dongle and connect to his wifi.
Deye has it's own app for mobile so I no longer user Solarman prefer the one from Deye it uses solarman credentials.
https://play.google.com/store/apps/details?id=com.deyesolar&hl
What
s the name of deye app
