Hi all
I have a clipping issue on my installation. My installation consist of
- Inverter: Deye sun-8k-sg01lp1-eu
- Solar Panels: 18 JA Solar 550W.
- Wiring: Two MPPT in use. First one with 8 panels in series. Second one with two string of 5 serial panels (5+5)
I have a problem in the production that can be easily spotted on the main production charts (see below). My conclusion is that the MPPT 2 (5+5 panels) is clipping at 20A. However the device specifications on the User Manual and Inverter sticker indicate a maximum of 26A. Please let me share some images to back my findings:
![1717667606281.png 1717667606281.png](https://diysolarforum.com/data/attachments/220/220067-9052b30578bbd92cb3c39c12ebc42750.jpg)
Day One Sample (31/05). Current peaks at 24A at 12:23 then it is clip at 20A for the rest of the day till the evening. There are no shadows afecting at that time.
![1717667727670.png 1717667727670.png](https://diysolarforum.com/data/attachments/220/220068-5c5dd5d6e41718af88acf9cb4462e25b.jpg)
Day Two Sample (03/06). Current peaks at 25.10A at 13:04 then it is clip at 20A for the rest of the day till the evening. There are no shadows afecting at that time.
The device specifies a max PV Input current of 26A both on the side sticker and user manual.
![1717668152080.png 1717668152080.png](https://diysolarforum.com/data/attachments/220/220071-4b95e8ffde323d963ed441646681c6d2.jpg)
Where the issue might be?
1. I have seen other discussions that the PV Input may be limited to 20A by the manufacturer. Please see link below.
Is that correct?
2. I have been scammed and my inverter is an older version with a fake sticker that only supports 20A max PV current.
3. I required a firmware upgrade. Is my current version the latest (see below)? How to upgrade the device?
Current version 0-6024-1724
![1717670748262.png 1717670748262.png](https://diysolarforum.com/data/attachments/220/220075-c6f477c27ae4576b53ab9e5ab38cec72.jpg)
4. I have missconfigured the device. See system work configuration below
![1717668950304.png 1717668950304.png](https://diysolarforum.com/data/attachments/220/220073-b3076d7a3ece9e33ea784d89af098eda.jpg)
Please share your thought and thanks for your help!
Is that correct?
