Alfalfameister
- Feb 21, 2020
- 50
Please explain something to me:
I have two packs in a battery bank. Pack A: 16S 105Ah, Pack B: 2P16S (280Ah cells) 560Ah. Each has their own Xiaoxiang BMS (aka Overkill). Both are connected to a busbar, to make the battery bank a nominal 665Ah bank.
So, 105Ah and 560Ah packs - 16% and 84% ratio.
Last night (until 05:30 the next day), I was discharging them a steady 1180W (as read by one Current Transformer - may not be accurate, but it's close). Took readings of each BMS. Total voltage was/is within 0.1v of each other (ie, like 52.89 and 52.81 or something like that), which could just be BMS's readings of each pack. I didn't take a voltage reading of the battery bank as a whole.
One would think that the discharge ratios would be 16% and 84%. But here are the readings I took when I had the chance (have to manually look, no logging, which would have been a LOT better):
Readings from EACH BMS:
About 17:00
7.5A and 15.5A (33%/67%)
18:00
5.8A and 17.2A (25%/75%)
21:30
1.3A and 21.7A (6%/94%)
03:30 (got up to pee, might as well look)
5.1A and 18.2A (22%/78%)
05:00
6A and 17.4A (26%/74%)
06:00
4.9A and 18.6A (21%/79%)
Turned on water kettle to make coffee:
17.4A and 46.4A (27%/73%)
07:00
0A and 9A (0%/100%)
Voltages are still within 0.1v (as they should be - they're probably identical, but each BMS reads it differently, and there might be losses from battery terminals all the way to busbars anyway).
SO... I am THEORIZING that they AVERAGE about 16%/84% anyway (if you check the ratio at 21:30, it's 6%/94%... and I didn't get to check at 21:00 or 23:00). They should still hit the LVD and HVD at the same time (because they are VOLTAGES), but SoC would not be identical throughout (but they would be close is my guess).
At first, I was worried that at the beginning (30%/70%), the 105Ah pack, if that ratio had remained, would definitely be discharged first. But I guess they even out anyway. Kinda like there's a stretchable string (in terms of SoC, not the voltage, which remains nearly identical) that when it gets to a certain point, they pull each other towards an equilibrium.
I don't really have a question, just thought I'd share, and maybe someone can explain why what happens, happens.
About 17:00
18:00
21:30
05:00
06:00
07:00
0A and 9A (0%/100%)
