I have a 206Ah SOK battery with a MPPSolar 12v all-in-one inverter/charger in a Mercedes Sprinter van that I installed last fall. I used the battery to charge small-draw appliances for short periods without any power source to make sure everything worked (it did). There was a small drop in voltage in the battery. Over winter I disconnected all the appliances, but left the inverter-charger attached to the battery but turned off. Temps this winter occasionally dropped beneath 0 deg F. Last week I found the battery drained to 3.4v. Last night I was able to charge the battery to about 12.8 volts using shore power, at which point the utility stopped charging. Sometime between then and this morning the battery voltage has dropped to 12.0v, and looks to be continuing to drop. No draw from appliances - they were switched off at the master switch. I left the inverter/charger on, and shore power available, and it did kick in for a short period. I don't have my solar connected yet (though its just warm enough to do that now). My question is whether the inverter/ charger, connected to the battery but not turned on, combined with the cold could draw enough from the battery to make it drop to very low. Or.. have I damaged the battery be letting it get too cold, or...is there no problem. And if there is damage to the battery what might it be and how can I tell? If there is damage is there a fix?
Please remember I'm a rookie so simple explanations are really important!
Thanks,
Ken
Thanks,
Ken
