ericmwalsh
- Nov 25, 2020
- 1
I have been doing solar designs for quite a long time and I am wondering if an old tech is now the best new tech.
I feel like a diversion load controller will offer a lot of advantages to a LiFePo battery set up, reducing cost and adding capacity.
I am up north, so a resistive air heater would work as a diversion load, but I'd imagine if I moved to a warmer climate I'd rather use water as the dump load, and further south an AC unit could potentially be a dump load - but I haven't put any work into that.
You should be able to get away with a 1600W solar array controlled by a cheap Tri-star-60 allowing you to use all the power from sun while keeping your batteries perfectly content.
And once you have the system for solar, you could use disgustingly cheap wind turbines or home made dc sources from a generator and let the TS-60 do the real battery battery management.
If you've done it I'd like to hear about problems you encountered. If you want to do it I'd be happy to help you with the design.
