Vigo
So as far as figuring out your 'available power', if you happen to get an adjustable DC-DC charger you should be able to find the 'sweet spot' pretty easily just by watching voltage.
General background info:
Alternators do not produce full output at engine idle. It's usually something like 60-80% of max at idle and max power is available anywhere from 1500 rpm and up.
Most car alternators are around 100amp (@1500+ rpm), but some can be upwards of 200 amps. Usually a vehicle with a ton of electrical equipment or a vehicle which is a 'basis for upfitting' (things that turn into police cars/limos/rv/service trucks) will at least have the option of a massive alternator.
Alternators are usually air cooled by an internal fan that spins the same speed as the alt. This means alternators are more prone to 'overheating' at idle than while driving just due to the internal fan spinning faster, plus there is usually a lot of ambient airflow in an engine bay when a vehicle is driving. If you have the rare vehicle with a liquid cooled alternator you simply dont have to worry about overheating it, period. But it's rare.
All you really need to do to figure out 'available power' is adjust your charge rate upwards until your voltage starts to drop close to battery voltage. The battery (depending on type) will only make 12.6-13.0 volts, so any time your voltage is above that, the alternator is meeting the need and the battery is not being drained. So, you can simply load the system until voltage drops to ~13.0, and that is the 'max available power' at that rpm.
Now, that is 100% of available power which means the alternator MAY gradually overheat and 'de-rate', so this is something you probably want to watch for at least 30 minutes before calling your settings 'final'. Some alternators have an onboard temp sensor in their regulator and will reduce their output to prevent from overheating themselves. So your 'initial' max power and what your max power is after 30 minutes of idling, may not be the same.
It's not actually critical to know the exact amps your charging system can sustain. You just need to make sure voltage is not dropping below 13.0, and you can be guaranteed that all that power is coming from the alternator and none from the battery. Knowing how many amps that actually is is just academic.
