Do I need isolator/solar disconnect when I have breakers?
kje
Do I need isolator/solar disconnect when I have breakers? Can I just turn off the breakers when doing maintenance on the solar panels? Like on this picture?
The breakers will be fine as an isolation switch too.
Whole different ball game if it is being inspected though.
What is the practical difference? Isn't it completely isolated with the breakers?
A DC isolator will disconnect both + and -. A breaker normally breaks only one leg (usually +). You can use a two pole breaker as a disconnect, assuming it is wired properly, to break both legs.
