timblack1
- May 19, 2021
- 24
I purchased 16 LFP cells and an Apexium battery box kit which includes a BMS from Jenny Wu. Everything seems to be in perfect condition. I am very pleased.
On my first voltage test after opening the boxes, 12 of the cells each have 3.256 volts. The other four cells vary by only one millivolt higher or lower than that. So currently they are balanced, but at a medium voltage. Their voltage is not at the top of the cells' voltage range.
The BMS includes an active balancing feature. I have not done an internal resistance or capacity test on these cells because I don't have the equipment to do so.
Should I top balance these cells before assembling and using the battery? Or, should I trust the BMS to top balance them for me while or after they charge for the first time?
