Daddy Tanuki
Solar Wizard
you can also blow a BMS as I found out the hard way. roasted two of them due to inrush current/spark on a 48 volt system. expensive mistake.That will do fine. Make sure you have proper pre-charge for inverter capacitors, since the inrush current can blow the fuse.
