I am installing Emporia Vue to monitor my usage. When I went to configure the lines I noticed that the oven breaker is setup to use two single pole breakers pulling from the same leg. Why would the electrician do it this way instead of using a two pole breaker? Can the Vue accurately measure the electricity usage or should I just swap it with a 2 pole breaker?
