bfaubion
After doing a lot of investigation, I decided to forgo a whole house 200 amp backup scenario with the 18kpv. What I do have is a partial home backup option, tying the inverter into a breaker in the house subpanel.
I’ve essentially got a non-used 40 amp breaker, with either stranded copper #8 or #6 that went into a smaller subpanel that housed breakers for an old wine cooler I tore out. So the little subpanel box sits there empty, with 2 #8 (or #6) lines and a ground coming in, at place where I could easily add the 18kpv… unless I will be severely limited by a 40 or 50 amp breaker (if it’s #6). I’ve also got a double pole 40 that goes to a 240 socket in the garage
Planning on 3200 to 4000 watts of solar, and maybe a single EG4 LL rack battery, or possibly the PowerPro. Average about 10 kWh per day when not using HVAC. I feel like the 18kpv is overkill for me, but it handles the grid tie and hybrid features great, and I could always require it in the future to whole home backup.
So I’m wondering, is wiring the 18kpv to a 40 or 50 amp breaker severely limiting? And is that an issue if my bus bar is 200 amps? (The sticker on the subpanel was removed, cannot tell if it’s 200 or 225, assuming 200 for now).
