Looking for opinions -
Current Config:
Proposed:
Rationale:
My Question
Current Config:
- AGM start, AGM House
- Both combined through Isolator to Alternator; Individual wiring from Shore power charging (40A), set to AGM profile
Proposed:
- AGM Start, LFP (280AH) House
- Alternator to charge Start only
- Start wired to Orion TR DC to DC Charger to House
- House bank disconnected from Shore power; wired to MPPT Solar and Orion DC to DC Charger
Rationale:
- Alternator protection (in the event the BMS disconnects the house bank while motoring)
- Charge voltage customization for house bank management - Shore power has multiple chemistry profiles but can only select one at a time. AGM Float 13.6V max , Bulk (can disable) 14.4V max 2hr; LFP Float 13.8V and Bulk (can disable) 14.4V, up to 16 hours
- Orion can play double duty to pass charge from shorepower and alternator to house bank
My Question
- Am I over complicating things by adding the Orion - It's a 30A charger so it may not be up to the 40A potentially from the shorepower charger (which means I might have to use the sterling 50A B2B charger).
- Are the charge profiles on my shorepower charger close enough that I can just use the AGM profile (13.6V Float or 14.4V Bulk and 13.6V float) to apply to both the LFP House and AGM start batteries (I suspect not)
