EBC-A20 com port issues
legg
Dusting off a never-used EBC-A20, V3.0.3, I find it will not identify itself to the PC software.
The serial usb adapter invokes a PL2303 driver for connection on com port 10 - which is
within the recommended port range, but differs from other website references to a
CH341 usb-serial driver.
Running a CH341 driver install makes no difference - Windows sees a PL2303 adapter.
No device recognized, com port search finds nothing, but the prolific driver is
producing com port 10 in the device manager correctly for cable insertions.
This is W7pro 64bit.
I'm looking at posts which concentrate on possibly-defective serial-usb hardware:
The replacement option shows 4 wires on the serial (EBC-A20) end.
Serial com (RS-232, RS-422, RS485 etc) normally uses only 3 wires ( TX, RX and Gnd).
Why is a 5V line added?
The USB end can get power from the PC's normal 4-wire USB connection.
Are both ends of the EBC-A20 connector actually simple USB, as the mini-USB
socket on the EBC-A20 suggests? Mini-USB expects 5V on pin1 (of 5pins - one pin is blank)
If so, why the drivers and 'special' cable?
I have possible replacement serial to USB cables that are recognized as CH341 on Com port 4,
vs the supplied hardware that identifies as PL2303 on com port 10, (but is not seen by the
EB software).
Both 5V and ground lines read as through connections when the supplied cables
are tested. The two data lines don't. Only the ground connection feeds through
on the possible CH341 replacement.
. . . by the way how does + and - translate to TX and RX in this situation?
Hardwiring the CH341 adapter into the EBC-A20 allowed the software to detect
a com port, but still no device is detected. tried swapping the com lines with
no difference - port detected but no device id'd.
In another link:
a correspondent suggests that tx and rx are reversed in the ZKEtech-supplied (prolific)
harness. Opening the clam shell shows white/TX , green/RX.
Swapping these over made no difference here - ie green/TX, white/RX in the clamshell
still loads as com port 10, without this port being recognized by the EB software and
no device is id'd by the EB software.
The correspondent said it fixed his issues.
In the earlier reference:
The correspondent who hardwired a PL2303A harness into the circuitry treated
green as TX and white as RX in his successful attempt:
Red = +5v
Black = GND
White = RX on PL2303TA
Green = TX on PL2303TA
Pin header photo attached
I should perhaps reiterate that earlier failures to connect made me uninstall/reinstall
the sw and drivers a number of times, with system reboot between driver changes.
I note that uninstall did not remove any non-default folders used. At present the
executable resides in C:\Program Files (X86)\ZKETECH\eb.exe dated 2021-08-01
v1.8.0.5
Each subsequent hardware iteration was tested after restarting the software.
It may be understandable that RX and TX connections may be confused if
regulation serial port hardware isn't employed - normal cables depend on
a Tx mating to Rx and vice-versa. This is why swapping these lines in an
unconventional hardware employment may be a necessary iteration.
I'm stumped.
RL
Its unfortunate you posted over 2 days with no responses.
It is a year later and I am doing the same thing, dusting off an unused EBC-A20 so I can test a new batch of cells that are on the way.
I am stuck at finding the correct USB cable. I haven't seen this connector in a long time and can't find anything in my stash that works.
This looks like an old camera cable...
I will contact Battery Hookup and ask what cable is needed!
I hunted at home and in the office for a standard mini-usb cable. I found 5 and none worked.
Not all mini/micro USB cables carry data, some are only for phone charging.
I found the USB-TTL cable that came with the ZTE. I had to install the correct driver, but not it appears connected.
Once i RTFM, will do a short test to see if it works.
I am testing an old Led Acid battery. Things appears to be working correctly.
