Mercruiser
I have a new EBC-A20 Battery Tester Electronic Load (as seen on Off Grid Garage and others). I'm really happy with the functionality of the device. I could not home-build a functionally equivalent device for the $89 delivered from China price on Aliexpress.
The expensive part of making a home-build equivalent is getting a remote voltage sense power supply, which compensates for voltage drop in the battery leads. I can only find this feature on really expensive bench power supplies.
Fan Replacement
After using the A20 for a couple of weeks, the fan's sleeve bearing started seizing up. I bought a replacement from Mouser. The A20 uses DC Tubeaxial Fan, 60x60x20mm, 12VDC. Mouser has lots of those for sale. Instead of the original sleeve bearing, I paid an extra $3 or so to get a ball bearing fan. I like quiet, so I sorted the results by Noise and chose the quietest fan that was reasonably priced at $12: NMB Technologies PN 06020SA-12J-AA-00
This fan works well and is a lot quieter than the original. At 12.7 CFM (0.36 m3/min) and 2800 RPM, this fan probably pushes less air than the original. But it seems to be plenty good for me. The air outlet temperature rise when charging or discharging at full load is minimal.
The hardest part of the project was re-assembling the case, due to the long header pins. See Andy's video at 9:30 (min:sec):
Next post: Power Supply Replacement.
Fan Replacement
