Hello all, I have just received the tester. It works because as I'm writing it is discharging a cell as I configured on the testers display. Before I started this test I was trying to connect it to my laptop. This is what I did:
- downloaded the software from this forum
- installed software and tried connecting
Figured out the com port which is 3 according to device manager. Now I should be able to connect with comm Setting in the ZKETEch software but it doesn't show a com port number.
- Decided to install the USB to TTL driver that came in the software package.
Same result.
- Restarted laptop
Same result.
Now what should I do next?
Edit: I also used "search comm port" in the tools menu without effort.
Same result.
- Restarted laptop
Same result.
