Eco Flow Additional Solar
Henryzm
California
I have a Delta Pro that is max’d out at 3 x 400 watt panels. 150V max solar input.
I would like to DOUBLE or triple my solar.
Is there an Inverter that i can purchase to hookup 3 additional 400 watt solar panels that can output AC without its own battery storage? This way i can charge my ecoflow thru AC and its native solar input ports.
I would rather not buy a second ECO Flow Delta Pro.
I also have an Delta Pro Extra Battery.
What you are asking for is basically an entirely separate DIY battery backup system.
If you are going to go that route, you're better off selling the EcoFlow and spending the whole budget on getting new system.
Your Delta Pro can do 1600 watts solar, so you are not quite max'd out with only 3x400 watt panels. You can add more panels by connecting in parallel, so as to not exceed the 150 volt limit.
