MrNatural22
?SW sunshine =⚡️⚡️lit up thru the darkness✌️
Just trying to find out if this is a normal thing. I have an Ecoflow D2 that allows 500w/60v max solar and has a 15a limit on the MPPT.
I have three 195w Ecoworthy bifacial panels in parallel because series would be to much voltage.
On a bright clear sunny day, panels at the correct angle to the sun I'm only showing 272w on the D2 display (dirty screen LOL). When I use my clamp on amp meter it is showing 14.67a coming in, close to the limit.
Is this normal solar wattage with the solar limiting on the Delta2?![Unsure :unsure: :unsure:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
(PS,I have a small heater plugged in as a test load showing 1159w.)
![D2 display.jpg D2 display.jpg](https://diysolarforum.com/data/attachments/181/181784-c088c2e1ecbbf460362992917d94a399.jpg)
![Solar meter.jpg Solar meter.jpg](https://diysolarforum.com/data/attachments/181/181785-735930e769fc57ceaefd39c9a3760455.jpg)
![ecoworthy panel specs.jpg ecoworthy panel specs.jpg](https://diysolarforum.com/data/attachments/181/181786-0acaf5fb28423911715ddacdbf8d6120.jpg)
