khbaur330162
- Nov 29, 2022
- 5
Hey all.
I recently bought an EcoFlow River Pro, it has yet to arrive. My question is, how do I ground my equipment that I plug into this thing? The outlets simply have a giant hole for the ground pin on US male plugs to sit inside, no electrical connection, see here:
![Screenshot (238).png Screenshot (238).png](https://diysolarforum.com/data/attachments/122/122262-cfb418672f191595cd7b7023907ca991.jpg)
I will be plugging in expensive hi-fi equipment to this battery backup and some of it is grounded. Sometimes I touch my equipment and get a small static shock. If my equipment is not grounded properly I am worried about damaging it.
I also bought this cable. There is a grounding screw on the side of the River Pro that this cable can run to and then just plug into the wall for grounding purposes, see here:
![Screenshot (239).png Screenshot (239).png](https://diysolarforum.com/data/attachments/122/122263-165578ec136b478fe37ed2151646a81e.jpg)
However that doesn't change the fact that the outlets on the River Pro are still un-grounded. How would I go about safely grounding my audio equipment?
This is especially important to me because I DIY'ed my own power cables for my audio gear and they have what's called a "drain wire" that spirals around the neutral and live wires (outside the insulation but inside the shielding) and connects to ground on the wall end (not device end so as to not contaminate equipment ground). This supposedly drains RFI and EM waves from neutral and live wires to ground, so I'd really like to maintain this feature in my DIY'ed power cables despite hooking up to battery power.
Any and all help would be greatly appreciated guys. I really don't want to ruin any of my equipment with shoddy DIY wiring, I've spent a lot on this equipment, so thanks for any insight you can give. Hopefully it's an easy workaround.
Best Regards,
Matt
Best Regards,
Matt
