Ody1980
- Nov 1, 2022
- 4
Hello,
I have bought and successfully installed a smart home panel with 2 Delta Pros. Now I have a question if anyone has the same setup - is there a bug with the current firmware or shouldn’t the SHP be able to charge the delta pros while giving battery power also to the circuits?
If I enable charging of both Delta Pros then I won’t be able to use the delta pros to also supply power to the curcuits. So if i set a circuit to use battery power it just goes dark without error because the relay switches to battery power but since both are charging there is no power so circuit goes „dark“ even though SHP shows green light indicator on that circuit.
So now my question why can’t i charge the delta pros while using its battery power as you could do with normal ac charging and discharging at the same time? And if that’s normal it should at least prevent me from enabling a circuit to
Battery power in SHP because you will have a „dark“ room then ?? I am using latest firmware.
Thanks for clearing that up,
Oliver
Oliver
