Kevink11693
- Sep 8, 2021
- 12
I just recently bought a EcoFlow delta and keeps blowing my 12v cigarette outlet fuse on my vehicle any suggestions how to fix this issue?
Get a vehicle with higher amp rated cigarette outlets?keeps blowing my 12v cigarette outlet fuse on my vehicle
Wow thats incredible. What kind of truck?My truck has a 20amp fuse
Do you have any way to verify the current draw?My truck has a 20amp fuse I plug it to the cigarette port It will run but but gets to 100 watts input and blows the fuse I was digging maybe a
BESTEK 300Watt Pure Sine Wave Power Inverter as a workaround
What does your “charger” look like?input from a car charger (in the specs it says 8A,
I'm using the cable that came with the Delta that has the lighter socket plug. I was just thinking to see if that cable's fuse (if there is one) blew. I've also tried a mini-inverter (smaller than the one HoboTech recommended in a YT video on the topic) and it drew nothing. I'll go check right now.What does your “charger” look like?
Is it by chance jus a power cord that plugs into a lighter socket?
Or, is there a chance you blew the fuse by pulling too much current?
Yea I tried that also it didn’t workI'm using the cable that came with the Delta that has the lighter socket plug. I was just thinking to see if that cable's fuse (if there is one) blew. I've also tried a mini-inverter (smaller than the one HoboTech recommended in a YT video on the topic) and it drew nothing. I'll go check right now.
NiceWhile we're talking...here's my van with the added solar panels (400 watt) with 2 that slide out from under while parked. Unless I forget to pull them in. ?
Such a ridiculous design. What I do is charge the Delta through my camper house AGM batteries early in the day, using the inverter I plug into 110, and charge it for an hour or so, then my solar setup or my alternator charges the AGM. I use the Delta exclusively for 110 power needs (fridge, cpap, laptop) which means I can turn off the inverter most of the time and keep AGMs as supplemental power. (thanks for listening).Yea I tried that also it didn’t work
