I notice my old 700watt microwave draws 1200watts
Wikipedia says 50-65% efficiency for microwaves, in converting AC power into microwave energy. So that lines up well.My understanding is the 700w number is cooking power emanating from the magnetron. The 1200w is what it takes to do that.
Inverter type or turn down the settings.I notice my old 700watt microwave draws 1200watts. Are there more efficient options available?
Medium power on a normal microwave is full power on off 50% duty cycle, so if his concern is max loading inverter microwave is only real choice I thinkInverter type or turn down the settings.
Yes, I think that is correct, we had the discussion in a thread a year or so ago and the microwave I had in my camper would cycle the amp draw. But it does help with a slightly undersized system.Medium power on a normal microwave is full power on off 50% duty cycle, so if his concern is max loading inverter microwave is only real choice I think
Not a concern overloading the inverter, I don't think turning settings down or cycling changes the efficiency. Just surprised by how inefficient it is. I assumed wrongly so that something labeled 700 watts drew 700 watts. Not the case on any I guess.Medium power on a normal microwave is full power on off 50% duty cycle, so if his concern is max loading inverter microwave is only real choice I think
I think for optimum efficiency you need an induction cooktop very little wasted energyNot a concern overloading the inverter, I don't think turning settings down or cycling changes the efficiency. Just surprised by how inefficient it is. I assumed wrongly so that something labeled 700 watts drew 700 watts. Not the case on any I guess.
I fell into the same trap. Ad said 700 watts and pulls over 1100 watts. Luckily my 12/1200 will run it even with the Starlink and entertainment center running, but to be honest it's just starting to get hot here so......Not a concern overloading the inverter, I don't think turning settings down or cycling changes the efficiency. Just surprised by how inefficient it is. I assumed wrongly so that something labeled 700 watts drew 700 watts. Not the case on any I guess.
Is that on a 20a breaker? Seems that would very easily trip a regular 15a.I have an inverter microwave and it draws 2000 watts on high/default.
The bad thing about inverter M/W's is they are not cheap. My standard 1000w M/W only cost me $95 brand new. Yes it pulls 1600w when operating. This is not a problem for my 3kW AIO except if I forget that I am using 2000w to heat the hot water tank up at the same time. Why manufacturers do not rate M/W for total running wattage I do not know. But a lot of small kitchen appliances are hard to find actual running wattage. Best to be available to supply a minimum of 15a (20a even better) for any standard plug in item.I have found with great consistency that microwaves, standard and inverter, draw 1.6X their rated output power.
The nice thing about inverter microwaves is that they actually operate at a reduced power rather than operating at 100% power for reduced time on a standard microwave.
Yes on a 20 amp breakerIs that on a 20a breaker? Seems that would very easily trip a regular 15a.
My $50 700w microwave also does about 1100w. If I would have known that I would have cought bought a normal wattage one.I notice my old 700watt microwave draws 1200watts. Are there more efficient options available?
Something about the 18K umm PV comes to mind. A 500 Watt PC power supply will draw more than 500 watts if it is actually outputting 500 watts. Depends on the reference perspective and marketing. A vacuum cleaner with a 10A motor often doesn't have a motor that actually draws 10A. In the case of a microwave the perspective is from the point of view of the food you are cooking, same as a PC power supply is from the point of view of the power supplied to the system, because that is what you need to know. A 500W input power supply does not tell you anything useful, nor would a microwave that uses 1000w necessarily tell you how fast it will cook your food, compared to another 1000w unit. You want to know output not input.Not a concern overloading the inverter, I don't think turning settings down or cycling changes the efficiency. Just surprised by how inefficient it is. I assumed wrongly so that something labeled 700 watts drew 700 watts. Not the case on any I guess.
Oh c'mon. I use my microwave every night, it runs for at least 10 minutes a day on average. So for a 1500 watt draw we are talking 249 watt/hours per day, 7.5KWH per month. Thats going to really make a significant impact on my electric bill and/or solar storage if I can shave it down to 200 wh/day. Save me at least $0.25/mo!I don't see that it's already been mentioned but this is where understanding power vs energy is important.
Watts vs. Watt hours
My gut tells me that For most people, the daily difference in Watt hour usage of the most efficient microwave vs. the least efficient is going to be hard to even measure.
