(60) 445 bi-facial panels - 26,700
(2) EG4 18k PV inverters
(12) 48v EG4 Lifepower batteries
I have installed very many systems, grid-tie and off-grid. This is the first time installing the EG4 18k PV inverters.
The homeowner has asked me to wire this system as grid-tie only. The manual doesn't provide any detail for a grid-tie only system.
I have powered both inverters from a battery bus bar - running two sets 2/0 cable to each inverter.
There is nothing set up from the Load and nothing set up for Gen.
I have installed an MLO with (2) 200amp breakers - 1 for each inverter. From the MLO, a single set of wires, L1 L2 Neutral and Grid are routed to a Disconnect box on the Supply side of the homeowner's service panel. This is the same way I have wired multiple Growatt inverters, multiple EG4 6500s, etc., with no problems.
I have set the Parallel parameters for each inverter as is specified in the manual. Upon commissioning the inverters, the inverter shows the PV voltages, it shows Grid voltage, does not show battery voltage. The Basic settings are Export to Grid and 12kw. The inverters did nothing. No fans, no grid export.
I called Tech Support. On hold for over an hour. Finally left the homeowner explaining that hopefully I get some help later and would come back when I had answers. Finally got through to Tech Support after returning to the office. Explained the whole issue. They said they had to e-mail EG4 and would get back to me. Have heard nothing.
A couple hours ago, homeowner called and reported that the Slave inverter "just came on." It was delivering about 6kw to the Grid. But the Master inverter was doing absolutely nothing. I can't imagine the Slave was working without the Master - but that's what was going on.
Anyone have any thoughts?
