ksmithaz1
Solar / EV Junkie
@EG4_Jared The above instruction should be polished up with better lighting / Size and placed in the manual!
More than likely it's some Chinese made variation of this I posted earlier.I literally spent hours looking this up. I'd never seen this style connector.
Place an appropriately sized screwdriver in the top I used a 10" bargain bin from Lowes.
Stuff it in the hole as far as you can flat high. Note the flat part is not visible.
Now peer in the hole and lift the handle , you will see the contact raise up inside the hole ... It takes quite a bit of pressure to move it!
Good luck!
It's why I have a combiner board even though I only have 2s1p my luck is awful so I over prepareExcept those springs the screwdriver has been pushed into may be at up to +/- 600VDC.
Lock Out, Tag Out, Test Out.
Or shut off inverter to ensure zero current flow, go on the roof or wherever the MC4 connectors are, label which is which (to later re-mate same pairs) and unplug all connections between these wires and the PV panels.
Then measure and confirm zero volts. It will probably be high voltage for a while as capacitors discharge. Wait patiently until voltage between positive and negative are something you're wiling to touch. Also between terminals and ground.
Use AC as well as DC range on DMM. Shut off inverter! Otherwise they terminals may carry AC.
(Don't be like me! And some other semi-lucky souls here who are still walking the Earth.)
I like a small visible ring to know we didn't pinch the insulation, but it depends on the connectorJust a pet peve of mine is all even if it is safe I don't like to see bare conductors but I'm still confused why I can see a slither of conductor in the photo then it goes solid before entering the battery terminal.
Quick Tip if you plan to work on this or remove them yourself. Please ensure solar array is disconnected or powered down when installing PV conductors! Very dangerous voltages here. Insulated thin screwdriver is ideal. Do not try to force it in if it does not fit. Need perfect size screwdriver to press that lever inside.I literally spent hours looking this up. I'd never seen this style connector.
Good luck!
You could take this very screwdriver and cover it with heat-shrink if desired. After spending an inordinate amount of time with this silly connector, ... It pretty well shrouds the contacts, they are wayyy back there, I would verify no voltage to ground before you stuff anything in the hole, but it's pretty much impossible to accidentally create a short if you do them one at a time, you would have to try by stuffing things into multiple holes at the same time.Quick Tip if you plan to work on this or remove them yourself. Please ensure solar array is disconnected or powered down when installing PV conductors! Very dangerous voltages here. Insulated thin screwdriver is ideal. Do not try to force it in if it does not fit. Need perfect size screwdriver to press that lever inside.
They work for me for my measurement for my net metering.I am going to ask a dumb question - but, aren't the CT clamps meant to go around the service entrance grid cables verse just the grid wires to the AIO? I mean they could just pick the presence and frequncy up internally from the terminals ?
Definitely a loose connection.Any ideas what could have caused this?
Yes, running in series. 10A per stringEG4 doesn't have replacement parts. The crimp on the ferrule looks poorly done. This failure is the result of a poor connection, most likely the poorly crimped ferrule, but could be on the other side of the connector.
I had a failure in the EG4 charge controllers. https://diysolarforum.com/threads/magic-smoke-came-out-it-happens.83412/ When I installed the replacement charge controller (remember, they don't have any parts to service units) I removed the top cover and tightened every terminal. Probably should do it again after running for a few months.
Are you paralleling strings? This should be about 10A for a single string.
No. It’s Bare wire into the terminalOh no, good point! That would be awful. Those need to be raw strands in that terminal.
Stick a screwdriver in the hole above it and push the handle up. Gotta have the right size screwdriver, but who doesn’t have dozens to choose from?you did a nice job and yoru pictures are really clear. thank you. I know when the installers were here they really struggled to get those windows open. Anyone found a trick to make the window open better/more?
NO! The ones on the 18Kpv don’t just push in. You must open the gate and push the ferrule in.There's a specific tool that looks like a bank of flat headed screwdrivers but that's generally just for removing, if you have the correct wire size and ferrule they should just push in.
No, keep the spring loaded one. I had a wire burn up on my SMA inverter that got loose after a few years of thermal cycles.Better yet replace this crap with a screw lug.
Please do, it took me a while to figure this outI will send the recommendation over to our technical writing team.
That’s what I was saying. Since they are in parallel you can just use an ‘external combiner (box)’It looks like the positive of 1A and negative of 1B is still good so you may be able to connect array to that.
