Eg4 3000 EHV shutdown and restart procedures
Ljg
South Louisiana
I would like to know the correct procedure to shut down and turn on the EG4 3000 EHV and also when putting solar panels, the correct procedure to add solar panels to the inverter/charger.
To shut it down,
  1. Turn off the solar,
  2. Turn off the inverter
  3. (if equipped) turn off any switch/disconnect/breaker between the battery and the inverter/bus bar
  4. Turn off the batteries, one at a time
To start it up,
  1. (if equipped) - turn on any switches/disconnects/breakers between the battery and inverter/bus bar
  2. if your batteries do not have pre-charge functionally, pre-charge the inverter with a resistor.
  3. Turn on your batteries, one at a time
  4. Turn on your inverter
  5. Turn on your solar.
Thank you for the info, as I could not find that info and wanted to do it correctly.
Thanks again
No problem. There may be some other specific things that I didn't account for that I'm unaware about your install, but genericly that should get you very close. If you like the help I provided, do me a favor and click that like button. Cheers!
Reactions: Ljg
