I have an eg4 3000 inverter on a hand truck with one 48v battery I’m using temporarily while building a stepvan. Awhile ago while using a power tool I got a shock, so a member told me to ground the case of inverter to the chassis, which I did.
Today when testing the 120v output plug of the inverter when it’s inverting (not passing thru) I get 80v from neutral to ground, and 46v from hot to ground. From what I understand reading other threads the inverter is not bonding internally to ground like it should.
Is the wire from the case to the chassis enough, or do I need to do a jumper wire also? Like do the jumper wire trick at the shore power input maybe? I was eventually going to install a shore power cord.
Edit:
I forgot, I’m also getting some strange surging happening on a fan installed. And the controller for the fan doesn’t work well like it did when plugged into the grid.
Edit:
