EG4 48v 280ah indoor wall mount battery, is it wall mount or not?
kampto
About to mount my battery to a concrete wall, was looking to elevate it off the ground and remove the feet. But then see this in the install manual. So is this a wall mount battery or not? Is the mounting bracket and battery case not up to the task? It comes with 6 concrete anchors. I have a 8inch thick concrete wall.
So its wall mount but don't fully wall mount it. Deceptive if true.
It stands up against a wall with a cleat to keep it from tipping over, but the weight bearing is on the floor.
Imagine a tall dresser up against the wall and you pull out the top drawers filled with heavier contents or a child climbs up the drawers and the dresser tips forward on them and crushes them (see Ikea Malm) The dresser is supposed to be attached to the wall with an anti-tipping bracket. Same for this battery.
