Ceefiveceefive
- Sep 28, 2019
- 94
Greetings!
My EG4 48V 100Ah batteries have arrived!
I have 3 and will place them in parallel for 300Ah total.
I am using an MPP 6048 Split Phase Hybrid Inverter.
I did NOT order the server rack that goes with these as my budget could not afford it. I called Signature Solar today and discussed how I could use them now until I can get or build a proper storage rack.
I was told that I can set these up without a rack for now by having them all face upwards. No problem there.
My question is if I should use battery cable wires to connect them all in parallel as I do not have busbars. The manual says NOT to connect battery cables. The technician I communicated with said I could temporarily use battery cables with a fuse.
I am willing to use this temporary measure until I either purchase a server rack or obtain my own busbars. What type & size fuse should I use for battery cables? Are there any other protective things I can do in the meantime with using battery cables (which are 6 AWG)?
Is it difficult to make my own busbars with material from Home Depot?
Thanks!
Thanks!
