Bridgetown
Hello,
I'm new to the forum, looking to implement an essential circuits backup system within my home.
My system is not built or purchase yet, but I want to get a reality check.
My power usage is currently being monitored and determined by a product from Emporia energy called "Vue". Emporia Energy - Vue
This product seems to be working reliably and was implemented by placing 16 current transformers "doughnuts" on circuits within my home's main service panel. Followed up by reviewing your power consumption on their app which works over Wifi on PC or phone.
My proposed system (so far):
1) Eco-Flow Delta Pros - My first impression was its a nice package, portable, power electronics seemed robust and a little expense.
My main concerns are driven from wanting to implement a smooth operating UPS system.
2) BLUETTI AC500 + B300S Home Battery Backup - Again nice packaging, good app. The cost of a second unit to make 240v got too expense for me to continue.
So...back to my system.
With my focus on acquiring an All-in-one EG4-6000EX low frequency inverter which contains a transformer to provide split phase @ 120v/240v output.
I found myself drawn to two new concerns that I have searched the forum community for help;
This most likely means, neutral current from my inverts autotransformer on ground wire will be caused by any imbalance in grid L1-N and L2-N as the result of autotransformer trying to correct any grid 120vac phase imbalance.
At this time, I not sure to what degree this is a problem. I already know that I will not be able to balance my loads perfectly much less being concerned about balancing my grid's transformer (assuming neighbors are connected). So I will need to do my best when I balance my homes loads. But what about the grid imbalance?
Looking for some feedback:
a) How much of my EG4-6000EX inverters (transformer) output capacity will be utilized trying to balance my grid transformer? Is there a way to measure or do I just have to hook it up and measure? Is this a typical concern that is dealt with somehow? Trying yo understand.
b) Are there other ways to help mitigate this situation?
- EG4-6000 inverter
- x2 Server Batteries & rack
- 4800watts of panels
- Reliance ProTran2 transfer switch R310C (10 essential circuits)
- Generator with 48V charge to recharge batteries (maybe EG4 Chargeverter)
- Eco-Flow Delta Pros do not allow charging from its 120v AC input power when the Dual Voltage Hub was enabled.
- Pass-thru current was limited to the 120v application (non-Hub) and the current was stated at 18amps (this is what I understand, not much information on the 240V operations)
- Neutral / Ground Bonding - My initial concern was simply try to understand the enormous discussions surrounding internal screws, stationary & mobile applications. An it appears now with, vendor Signature Solar's commitment to the February firmware of common neutrals and "no screws" that our forum leaders (Filterguy, Hedge, Timelectric, RCinFLA) have managed to document and sort out various implementations to help remove ambiguity surrounding the topic. Many thanks for your efforts, your work in this subject area is appreciated. Your dedication to properly document is situations where manufactures do not share their schematics is a great value to someone who is new and trying to build their first system!
- Common neutrals when using an low frequency all-in-one inverter with a transformer - Some concerned still exists with paralleling transformers
