Marobel
Just to be perfectly clear, I’ve already had a discussion with Jared from EG4 about this. He’s not sure if this is possible but replied that he’s asked the aEG4 technical staff about this. Jared, not trying to upset the Apple cart here. Just trying to get a consensus on this topic.
I’m wondering if there are other folks out there that are in the same situation as I am. How many of you would like to see their 6000 XP be able to use 120VAC as the AC input plus/instead of the 240VAC split phase currently required? As many of us are doing, this is going to be in a totally off-grid situation. Maybe out at a remote cabin site or private property somewhere in the boonies. Having to feed this with 240 V split phase AC is going to be troublesome. (Impossible) My small generator outputs only 120 V and there is no Electrical connection to any grid. Do you think a software change is possible or would this require an internal electro-mechanical modification? I fully understand the reduction in the pass-through amperage and the reduced battery charging capacities. But at this point, with only PV input, this is not going to be a long-term solution I can deal with.
I guess what I’m asking from EG4 marketing is what would it take to get an inverter for our demographic?
As I read in this forum and a few others I follow, the technical data sheets on this off grid inverter were a bit confusing. This has been reposted to General Discussions and edited a bit for clarity. I’m going to remove the other posting immediately.
