I'm looking to buy my off-grid solar system in the next 6-9mo and I now finally feel like I'm in the window of time where there wont likely be a new piece of equipment released that will change the plan so its time to get serious about getting the equipment spec'd out.
I have a shed that will house my batteries and inverters and I plan to feed a 200amp panel in my shop and a 200amp panel in my house with AC from there. Ideally, I'd like to set up my system with 4 6000XP inverters to start and add if needed. Following a recent video from Will on the 6000XP it seems very straightforward to use a standard 200amp panel as the AC combiner box but how does this work in practice? In this case, wouldn't the 200amp breaker trip before I ever got into the surge capacity range on the inverters?
I searched but am likely searching the wrong terms so I haven't been able to find much. With all of these new stackable inverters able to provide well over 200amp AC, what's the go-to solutions for combining their AC outputs when you get 8+ inverters?
Thanks,
Spencer
Thanks,
Spencer
