Hi all, I finally decided on the 6000XP for my needs, currently connected through a Reliance 10 circuit transfer switch to my panel. I plan to also use the grid as backup when the SOC on the batteries is low, such as on cloudy days.
Fom the transfer switch, the L1, L2 are connected to the AC output of the 6000XP, and am running a ground and neutral wire from the respective busbars in the 6000XP to the busbars in my panel. For the AC input, I have a L1 and L2 from a 30a double pole breaker in my main panel.
Question is if I also need to run another set of neutral and ground wires from the main panel busbars to the 6000XP neutral and ground busbars for the AC input? Manual did not really address this. TIA
