D. Abineri
My previous split phase inverter accepted 240v and a ground from my main house panel (new construction) and the output was 240v (on black and white wires) and ground. I had the black and white output powering my sub panel along with the ground so that a double pole breaker gave me 240v and a single pole gave me 120v. I am trying to replicate this with the 6000xp.
The manual for the 6000xp shows black and red as the 240v input to L1 and L2 along with ground and neutral on the corresponding bus bars. Now, the output from the 6000xp shows black and red (at,I presume, 240v). Do I power by sub panel with these red and black wires? Where do I connect the neutral and the ground from the inverter in the sub panel?
My main house panel apparently does not seem to have neutral grounded (bonded) because I can measure 120v between ground and black, and ground and white.
So, how do I connect up my sub panel so that it works as it did with my previous inverter, giving me both a 240v line and some 120v lines?
When Will tested his 120 output from the 6000xp, he did not show where the connections on the inverter were made.
Thanks
Thanks
