Explain what and where you are measuring please.Entering the inverter about 20 feet from the main panel.
I am measuring voltage between ground and neutral, and ground an black (open circuit) that were entering my old Growatt inverter before being connected to the inverter.Explain what and where you are measuring please.
There is no neutral at that location.Entering the inverter about 20 feet from the main panel.
The input to the Growatt is a 240v line (black and white) and a ground. The output is the same that I have been using for my sub panel.There is no neutral at that location.
I think you mean between white and ground, which would be L2 and ground...I am measuring voltage between ground and neutral, and ground an black (open circuit) that were entering my old Growatt inverter before being connected to the inverter.
That cable doesn't have a neutral.The input to the Growatt is a 240v line (black and white) and a ground. The output is the same that I have been using for my sub panel.
You were using ground for neutral.
I am thinking of black and white as L1 and L2. And the potential of each of these to ground (the bare copper wire) is 120v giveing the total 240 v between L1 and L2.I think you mean between white and ground, which would be L2 and ground...
In this case, you are not running a ground, you are running a neutral.I am thinking of black and white as L1 and L2. And the potential of each of these to ground (the bare copper wire) is 120v giveing the total 240 v between L1 and L2.
There are only three input terminals on the Growat. L1,L2 and ground. Black, white and bare copper.In this case, you are not running a ground, you are running a neutral.
You STILL need a ground.
Pictures.There are only three input terminals on the Growat. L1,L2 and ground. Black, white and bare copper.
The bare copper comes from the ground bus bar in the main panel where all the grounds for the house circuits meet.If it produces 120v and 240v it has to have neutral and ground.
The black and white come from a double pole breaker in the main panel.Th
Yes, Please look at the Growatt SPF 60000T manual online if possible.You only have 2 hots and a ground.
There is no neutral in that cable.
That's 6000TYes, Please look at the Growatt SPF 60000T manual online if possible.
Correct, so where does that leave us.I am familiar with that unit.
It's input is 240v 3-wire single phase.
Two hots and a ground.
No neutral.
You need to run a new cable.Correct, so where does that leave us.
