@ Zwy
I have observed this very same effect myself, it only does it sometimes on very light loads when solar input exactly matches the inverter load.
If something changes, where inverter load is either increased or decreased very slightly, the flickering stops.
Also if solar changes slightly due to variations in cloud density, the flickering stops.
It comes and goes, but only seems to do it around sunrise and sunset, and only for a very short time.
As far as I can see, its due to the voltage characteristics of the battery. If a battery is just sitting with nothing connected to it, there will be a certain measurable voltage.
As soon as you start charging, even at very low current, the voltage jumps significantly upwards.
Likewise if you connect a discharge load, even a very small load, the battery voltage jumps downwards.
If you are running where charging current and load current are equal, the battery may be right at the point of either charge/discharge, and the battery voltage can jump up and down by enough to cause light flicker.
It never happens during the day while charging, or at night when there is only discharge.
I have only seen this effect at dawn and dusk where we are transitioning between day and night.
Sometimes its only one or two flickers, sometimes it can go on flickering for several minutes.
Not sure what to do, but will very soon be greatly increasing my battery capacity from 5Kwh to 28Kwh and hope that fixes it.
If it persists, I might try some ultracapacitors. As it is now its tolerable, as the point at which it occurs I really do not need lights switched on.
But I would still like to understand better the exact cause.
