Adam De Lay
Solar Wizard
All 4 are the older model that came with the grounding screw.
Well, that squishes that theory then.New model (post Nov 22) (grey terminals) is the one with the issues.
Yeah as long as it's up by 8:30-9 which is generally when my big loads start. That would be a real problem if it did it all day. It's the intermittent clouds that I think trigger it. If it was super cloudy all day I imagine it could get stuck. I've only had it running for a couple weeks and I live in a desert.I havnt had any full cloudy days, but I would be happy if it fixed itself before 9am. It was mainly a problem for me in winter where it would be cloudy all day and would never fix itself.
yep, the newer one of mine has that sticker punched 9/2022 and had the new grey input/output terminalsShould be a new version, bought this spring after they started shipping with no neutral bond
Yes, no shading but they're south facing at around 18 degrees for string 2 and 30 something degrees for string 1. So they're not getting very direct sun that time of day.Yeah, something still isn't right. Are your panels out in the open so they get good exposure between 0630 and 0730?
No this isn't meeting my threshold of wanting to mess with a ticket yet, will hopefully eventually be resolved with firmware. If it starts doing it for longer periods of time then yeah.Have you opened a ticket with SS?
What problems did you have that it didn't fix or what problem are you having. So far everyone that was having issues are good to go now.@Markus_SignatureSolar any other ideas? Seems like the firmware didn't make any difference.
I still haven’t updated my firmware, so I do have the same issue but it hasn’t really mattered with the nice weather and long days.
I have an older model (pre Nov 22) (black terminals) and that is the one that works fine. New model (post Nov 22) (grey terminals) is the one with the issues.
Can you send me your info it sounds like you are having a hardware problem software cant fix.What firmware are your inverters running?
I was having on off issues and upgraded to 79.70 due to the inverters turning off and on randomly.
After the firmware upgrade the on off issue is still random and have a new issues where the inverters turn on and off when the PV power starts to increase at sun rise and when the batteries reach 100%.
@trig2 commented earlier in the thread that he updated to 79.70 and is still seeing the problem.What problems did you have that it didn't fix or what problem are you having. So far everyone that was having issues are good to go now.
Updated to 79.70 a couple days ago. Seems to be the same. Here's this morning. I have noticed clear mornings are the worst, clouds seem to trigger it to sweep so it doesn't get stuck for so long. It did fix itself this morning.
Flipped breakers this morning.
We are talking to him currently.@trig2 commented earlier in the thread that he updated to 79.70 and is still seeing the problem.
Please send your info to me so I can get someone talking to you soon.All 4 of mine do it. 2 are from 5/2022 and the other 2 are 7/2022
On here, Can I private message on this forum? Not seeing the option.Please send your info to me so I can get someone talking to you soon.
you can ignore this. I think I figured it out.On here, Can I private message on this forum? Not seeing the option.
They pmd me but I didn't pursue it.Was SS able to provide any help/insight into your issue?
