EscapedAritst
Hi All,
So I've bought - and will soon assemble - the following equipment for two off-grid setups (two different homes):
4 EG4 6500ex-48 inverters
36 455W panels (9s each going to one inverter...no combiner)
6 (soon to be 12) EG4 48v batteries
15kw Generac generator (to be purchased this week) just for one of the homes
I have a couple of questions about hooking up the generator (at one home) or the grid-as-a-backup (at the second home). I know the inverter has AC inputs for either the grid or the generator. What I can't find information on is automation and transfer switching. I have read on other inverters, that I can set them to start the generator. I think there is some kind of switch on the EG4 but I can't find it in the manual description.
Then on the other home, the AC from the grid will be connected as a backup (not grid tied). On this one, I assume this is the same problem but without an on/off for the generator. However, it still needs to know when the AC from the grid should be used and when it should be ignored. Also, I assume you can set it so that it can never back feed the grid?
