I updated to v24 firmware (the 09.19.23 file from EG4) in hopes to improving charging compatibility with my batteries, but now I'm having problems getting it to charge at all! My current settings:
- Work Mode: Battery priority (to force charging)
- Charge Current: 10a
- Advanced mode: Disabled
I'm hoping you guys can confirm my understanding of some of these screens:
- The Battery Info and BMS Parameter screens suggests that the battery BMS is communicating properly to the inverter, correct? The voltage and SoC match the what the individual BMS screens on the 2 batteries show.
- The "STA" screen showing "C D" indicates that charging and discharging are allowed, right?
- Does the State screen ever show "battery" on the SYS line? Mine currently only shows PV and Grid. DCDC shows "Charge". But as shown in the Power screen, I'm only seeing noise for the battery power (it flops around between 0 and 30w)
I've reset the system several times since doing the firmware update, and it seems charge for a short while, but then stops. I've also tried setting the battery type to lead-acid and it still does not charge! I guess I'll need to revert back to the v23 firmware if I can't get this charging issue resolved. Thanks for any insight you can provide on this.
