OffGridInTheCity
Solar Wizard
I have a Champion 100297 hooked to my EG4 Chargeverter. The Chargeverter is set to 100a and I leave it all turned on.... the Chargerverter breaker is 'on' and the AC distribution panel is 'on' etc. When I start the generator, the generator delays a few seconds (10sec? 20sec?) and then the Chargeverter load kicks in and the 100a charging starts which is ~5600w load on the generator at 50v battery voltage.I've found sometimes whatever your plugging your chargeverter into can't handle the surge on startup. I have to start at a lower current and then ramp up manually for it to work properly.
I've done this ~5 times now and it seems to be working - but that's not proof it will always work. On the other hand, I can't think of a theory for 'surge' except maybe the generator has trouble meeting a 5000-6000w semi-instantaneous load?
What do you think is happening to cause a surge?
