sjordan0228
I believe I have all my settings good for now and understand them. I was running Solar Assistant just connected to my inverter (EG4 3000) and set the battery type to EG4 Battery Protocol. Everything looked good and was reporting but it was not reporting the temp of my battery. So I figured maybe this is something that has to be done from solar assistant connected directly to the battery. So I set the dup switch to UDDD, shut the battery down and connected the SA to to Battery. I also change the battery protocol to User-Defined. Started everything back up and connected the battery. It found it!
I now have temperature showing, but now its not reporting any battery usage on the Dashboard. It shows the battery percentage and voltage and the actual load but does not show me that the load is coming from the battery or utility. I feel like an idiot yet again. What am I missing?
